Today I was going to replace the purge solenoid valve in my Mazda 3 2006. I was having problems starting up the car every time after refilling gas. I in a post that the likely culprit was the solenoid valve and that it was an easy fix. First I disconnected the line on the front side of the car without issue. Then I disconnected the line on the other side (closer to the cabin) and noticed a little bit of gas came up. Not much but enough to wet my fingers (a few mL). Is this normal? I though this line will only carry gases and non liquid fuel. About 2 weeks ago the car started running with higher RPMs when shifting gears. It goes to 2000 rpms and if I hold the clutch it will go back to normal after 2-3 secs. Should I still switch the purge solenoid valve or if there is gas in this line do I need to fix this problem?
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Dec 21, 2018 at 13:50
1 Answer
OK this is embarrasing!! I pulled the wrong line. Whatever was the other line is probably the one that brings gas to the engine. I guess the lesson is do not try to do this late at night with very little light!
please edit this into your question do not post it like an answer or a comment. Jan 16, 2020 at 7:14
