I have honda fit GP1 (Manufacture year - 2013) and well maintained. 78000km is done up to now and I normally use 10W30 synthetic oil. as I feel engine oil is burning faster than normal vehicle. After service I can run nearly 3000km without refuel engine oil. here is my problem.
last week when I drive suddenly I see engine check light turn on and in my IMA shows
VSA warning
after that I can not drive car because when I accelerate car does not go foreword. After I carry car to technician he said that this is common problem for Honda Fit GP1 modal, you have to replace piston set and do engine overall.. :( what is the problem here and what should I do..?
Note: technician showed me spark plugs and said oil is leaked to spark plugs. After he washed all spark plugs, then issue was fixed.
  • The technician told you what the problem is... Up to you to decide if you want to do that work or get another car.
    Dec 20, 2018 at 8:25
3 Answers 3
Before you look at having any overhaul or similar done at a third party it's worth checking with your local Honda dealership as there is a recall for the Fit GP1 regarding the oil consumption issue.
Basically there is a flaw in the design of the pistons which allows a dirty sludge/deposit to form on piston ring, this means the ring doesn't seal properly and oil then leaks into the combustion chamber (initially manifesting as oil consumption and ultimately misfires and a general failure to proceed).
I believe the first steps they take is to clean the pistons/rings/plugs (and then presumably cross fingers and hope it doesn't happen again) or if it reoccurs then they replace the pistons and rings with an updated design.
Edit:
To expand upon my earlier thoughts it's worth clarifying what the technician actually did - if they only cleaned the plugs then the buildup on the pistons/rings is still there and the problem **will* be back relatively soon. The pistons rings and oil return hole also need cleaning or oil will start building up on the plugs straight away.
  • So, basically what the technician told the OP...
    Dec 20, 2018 at 10:27
  • @SolarMike yep but with added "why" and bonus recall info Dec 20, 2018 at 12:33
Thank you @motosubatsu for your answer. I checked with my local Honda dealer about free repair and they said that because of that Gray import there will not be free repair.. :(
I think they only clear spark plugs and did engine tune up. what is the best solution for this.. ? is it clean pistons/rings or replace them.. ?
lets say I replace those pistons and is there any chance to occur that problem again.. ? what is your suggestion about use this vehicle for long time or is it good to change vehicle. because I can not afford more repairs like this..
  • I have experienced the same problem and contacted Stafford Motor(Honda agent in SL) . They said that Honda has officially sent a proper modified parts to solved this problem.Now they have a permanent solution for this which is replacing rings,pistons and few other parts.Even though this is a design failure they charge this for around LKR200,000/= which is unacceptable. Jan 1, 2019 at 5:41
Before spending money on any major repair. Try this:
Drain whatever engine oil is left in the engine. If you have good level of clean oil then you don't need to drain.
Fill the engine with 2 litres of flushing oil aka cheapest engine oil that you can get - it must be thin oil.
Add engine flush. I used a can of WHIZ. Now keep your vehicle on a flat surface, and idle the engine for 3 to 5 min.
Drain oil. In my case to my horror the oil was all black.
Refill with 5w-30 synthetic oil. Do not go for thicker oil like 10w or higher. 0w 20 for areas with cold weather. I live in Karachi, Pakistan so this suits me during winters.
Enjoy your ride. Keep monitoring oil level and oil color. It should stay fresh Monitor your vehicle. I experienced better mileage and still monitoring oil level as it's just one day has passed.
