When my car rolls forward, the steering wheel turns quickly right then left, right then left, back and forth, the same small amount each time. At higher speeds the car shakes, and it seems to shake the worst when just at 60-65 mph. The problems seems a lot worse after a drive to PA and back from Washington DC.
The tread on my tires is definitely low, Im saving to get new ones. The alignment isn't centered either, it pulls slightly to the right when I let go of the wheel, but I never saw it as a problem.
Could this be from the lower control arm bushing? A mechanic told me that it would need to be changed soon. I looked at them though and they seemed to still be intact.
Any advice is appreciated, thanks for reading.
