Okay, so yesterday I stopped at a traffic light on my way home from uni. When the traffic light turned green again, and I was to pull away I could not get the gear into first no matter how much I tried. After 2-3 mins I gave up and set off in 2nd gear, which I did for the most of the way home trying not to hold still with the car and thus avoiding to have to use 1st gear.
What do you reckon the issue could be? I have tried for one hour it's simply STUCK, whether you hold the clutch down or not or whether the car is on or off, it doesn't make a difference, it won't go into first gear physically, it's like it's blocked or something.
Also, anyone got a clue how much this would cost me?
Lastly, since i've had to start off in 2nd gear , I try to accelerate more and slowly let go of the clutch and it seems like it's not struggling too much. But I'm sensing it's not good for the car. I've done this about 6 times now. Will have it checked tomorrow but after I make an additional 2 drives. Could this potentially cause worse damage?
Car: VW Polo 1.2E (2008)
