Is it is safe to remove the "cat" in my vehicle? I have been losing power even after replacing the turbo.The cluster lights up the "diesel particle filter" sign. I have intermittent bursts of black and white smoke.
Removing the catalytic converter most likely will not fix your problem.
The DPF is a separate part and it needs regular cleaning - usually it runs through a controlled cycle triggered by the control ecu.
If you do many short runs, lots of stop/start and ignore the cleaning cycles, then it gets to a point where the garage has to remove it to see if it can be cleaned or it needs replacing.
| improve this answer | |
  • Not to mention you will likely fail any emissions test! – GdD Nov 24 '18 at 9:27
