Last night I noticed by headlamps weren't working ... I rotated the knob and only the day running lights remained on. I toggled full beam and that worked... so it's just normal beam and whilst I was turning the dial back and forth, a message appeared on the cluster stating "low beam bulb fault".
Having both sides go at the same time feels not normal so I suspect it's potentially a fuse or relay. I've had a look at the manual and the fuse diagram but can't find anything for headlamps... can someone help me locate it?
thanks
