First had this issue 6 months ago, Engine slowly stalled then when attempting to restart it died out after 10-15 seconds of running with some smoke coming from the front of the engine.
Diagnosis was showing DPF filter so cleaned out DPF and inlet manifold only to still have the same issue.
Diagnosed again seemed to display an issue with the fuel supply so switched the fuel rail and changed the battery car was then running fine and actually passed the new style MOT! Up until last week following a service inc oils/filter changes. Car seemed to lose power during driving and eventually stall and when attempting to restart it died out after 10-15 seconds of running.
Engine would continue to cut out after starting the ignition. Diagnosed again when it began to run for a while and attempted to drive a short distance. There seemed a slight difference within the airflow levels to and from the turbo so considering sending turbo to a specialist but thought I would reach out first to see if anyone has had a similar issue before?
15
  • Welcome to Motor Vehicle Maintenance & Repair! Nov 20, 2018 at 11:27
  • Thanks @Paulster2 ! Know anyone that could help with this issue?
    – ATANKS
    Nov 23, 2018 at 13:42
  • Update - have since blocked off the EGR and car is able to start and run without cutting out. However, smoke is still visible when revving on standstill.. Have previously cleaned the EGR but half bought a sourced a new one to see if it resolves the problem If anyone else has had a similar issue please get in touch, will update with findings after changing EGR this week!
    – ATANKS
    Dec 3, 2018 at 13:30
  • Is the smoke black or blue? Dec 3, 2018 at 13:33
  • Blue as its grey seems to be coming from the back of the engine and even thought the car is running with EGR blocked off it still feels clunky when applying the throttle... changing EGR tonight so will see how it drives then and if the smoke clears?
    – ATANKS
    Dec 4, 2018 at 13:16
