I have a manual Toyota Camry . I find that I cannot get out of first gear when I go above 2000 rpm . It is stuck in first gear until I slow right down to 1000 revs . Then I can move into second gear.
The fluid in gear box has been drained and replaced. The clutch is 6 mths old .
    Welcome to Motor Vehicle Maintenance & Repair! Two things to check: motor mounts & shifter linkage bushings. – Pᴀᴜʟsᴛᴇʀ2 Nov 10 '18 at 13:05
