Smoking battery when jumping it and when I tried charging it the voltage meter kept jumping up n Down. Also while the vehicle was running it just completely died on my 2005 Acura MDX. Does anyone know what may cause this. But when I took the battery out of the truck and tried charging it. It didn’t do that. Can this be electrical? It first started getting the jumper cables to get hot n started smoking
9
  • Welcome to Motor Vehicle Maintenance & Repair! You are saying it was "smoking" while charging inside the vehicle (I take it the vehicle was running and you were charging it off of the alternator)? – Pᴀᴜʟsᴛᴇʀ2 Nov 6 '18 at 19:17
  • Is the meter on the charger actually a current (not voltage) meter? Sounds like when the battery is mounted in your car there's almost a short circuit from the positive terminal to the ground. Was the battery touched (removed and replaced say) prior to your first having trouble? – mike65535 Nov 6 '18 at 19:19
  • No I meant smoking when I tried to jump it t – Alicia Leyvas Osife Punkin Nov 6 '18 at 19:23
  • @paulster2 When I tried to charge it with battery charger the voltage meter jumped up n down. But when I tried to jump the battery with another vehicle the cables got hot and the connection to battery started to smoke – Alicia Leyvas Osife Punkin Nov 6 '18 at 19:23
    @Mike65535 no the cables r on positive on positive. I’ve jumped many vehicles I know to look . Thank you for that though.😊 – Alicia Leyvas Osife Punkin Nov 6 '18 at 19:34
