I have a 2002 Ford Explorer XLT 2WD 4.0 6 cylinder Gas
I don't know how much of that matters for a camshaft sensor, but for some reason I got urge today to test my camshaft sensor, when I did I got an ohms reading of .756
I don't know if the ohms reading is different for every car and truck, or if it's generally the same. Personally I think it's low because I seen a video saying a good reading for a camshaft sensor is 2.0 ohms (2000) and my vehicle has had a misfire for awhile and the mileage reading will jump from from trip to total mileage driven randomly
  • is this a 4l sohc or ohv?
    – Ben
    Oct 30 '18 at 20:39
  • I believe it's an ohv but don't hold me to that
    – user38183
    Oct 30 '18 at 22:28
If the camshaft position sensor (CPS) is a Hall sensor, it works by translating changes in magnetic field to changes in voltage via inductance.
Such sensors can degrade with time (and use) through demagnetization; measuring its internal resistance will not indicate this type of degradation.
  • So how are their magnetic fields tested
    – user38183
    Oct 30 '18 at 8:21
    That's a good question which should be asked separately.
    – Zaid
    Oct 30 '18 at 8:43
  • If you want to get into the weeds with it and use an oscilloscope, that's your prerogative - But the dealer will have a computer to gather more insightful data.
    – Aww_Geez
    Jan 21 '20 at 17:19
