I have next issue: a hose of the rear window washer fell off and I have no idea how to put it back. I tried just shove it back by force but without result. Looks like it has a clever way to put the hose back to the connector.
Have anybody idea?
  • Welcome to Motor Vehicle Maintenance & Repair! Commented Oct 21, 2018 at 13:09
You can get some “softer” silicon pipe that bends easier and use a straight connector.
One trick is to remove the jet and as you push it back into the hole , you push it into the pipe at the same time - this gives effectively more space to work...
  • I don't think the "getting it into the hole" is the issue. It appears to me, the problem stems from the angled portion on the hose not staying in the connector. I'll bet this will require replacement of the connector. Commented Oct 21, 2018 at 13:09
