I drive Nissan Sunny 2010 N16, it has 225000 KM, I am experiencing extra fuel consumption, for 45 Ltr it makes only 350 KM in average (high way/city) driving, one week back I changed the oxygen sensor but no luck, now I am thinking to change the Coolant Temperature Sensor cause it has been for long (5 years, 180000 KM) not changed
    Is there any reason to think it's failed? Engine code for instance? Commented Oct 21, 2018 at 0:03
  • no engine code at all Commented Oct 21, 2018 at 6:29
  • BTW - Welcome to Motor Vehicle Maintenance & Repair! Commented Oct 21, 2018 at 13:14
Some of the sensors on my car have done 200,000km so don't just change them... It is easy to spend a lot of money changing the wrong thing...
You should check for error codes and make sure the service items are good ie is the air filter clean, fuel filter, plugs and you should also check the tire pressures.
  • I change them cause I get extra performance enhanced, as a sample the transmission got well and smoothly when I changed the Oxygen Sensor Commented Oct 21, 2018 at 6:32
  • air filter clean every oil change till it gets free of dust, spark plugs changed 3 months back, tire pressure as mentioned I check every 15 days, it doesn't show much lose Commented Oct 21, 2018 at 6:36
    @MahmoudHboubati - You're mixing apples and oranges here. Air/oil filters are maintenance items and should be changed regularly. A sensor should last as long as it's going to last ... you don't need to change it in the meantime (ie: there are some exceptions like the O2 [or lambda] sensor). Changing out a temp sensor will not give you any better performance or fuel economy unless it has failed. Commented Oct 21, 2018 at 13:13
