Hi i have a little problem there. yesterday i found one of my cylinder stopped working, i swaped coil 2 to coil 3 (my car has only 3 cylinders), and i found that the coil nr 3 stopped working because when I've put coil nr 2 to nr 3 then the 2nd cylinder was not working. So it doesnt look like it's a spark plug or cables....
I thought it was only 1 coil gone, bought the new coil today, put it in and then there was still only 2 of them working, is it possible that another coil just went off? (i mean not the new one).
Maybe the spark plug in cylinder nr 3 is faulty and killing the coils? because the coil worked fine before i swaped it to nr 3 cylinder., then it was running a bit yesterday while doing the tests and i found out today that it just stoped working but it worked yesterday.
I've put the new one to cylinder nr 3 and it's working... so i don't know if this cylinder is crazy or what?, so maybe just bad coincidence?
new coil seats now in cylinder nr 3, i want to get another new one, but just afraid that cylinder nr 3 may cause the new coil to fail, is it better to change the spark plugs too?
sorry for my bad english..thanks in advance
