Once I jump the car and it's running with the Positive lead on the positive terminal and the negative lead on the negative terminal I can turn the engine off and start it back up within around 10 minutes after it's been shut off. If I wait much longer than that the car will not start up as the battery is not fully charged. Now if I unhook the positive lead from the positive terminal after I turn off the car, it does not seem to drain the battery and the car will start after the lead has been attached back to the terminal.
    Welcome to the site. You've stated some conditions, left out some important ones, and haven't really asked a question. What kind of car? How long have you had it? Is this problem new? Is the battery new/old?
    – mike65535
    Oct 16 '18 at 16:59
  • So fit a battery isolator switch... have you had the battery tested? That may be one of the issues...
    Oct 16 '18 at 17:06
  • Could be a pletora of things, but the most common should be a wire grounding somewhere? Always disconnect the black wire, not the red one.
    – dmb
    Oct 17 '18 at 12:54
