Recommended oil viscosity is 10W30 for my motorcycle but temperature outside is getting higher these days it reaches upto 38 degrees on some days.Is is fine to continue to use 10w30 grade oil or I can switch to 10w40 grade oil without side effects
  • Don't switch, The oil temperature when the engine is hot is much higher than the air temperature - it should be around 100C to 120C. Switching might not have any seriously bad side effects, but it definitely won't have any good side effects.
    – alephzero
    Oct 13, 2018 at 20:49
  • Basically a duplicate: mechanics.stackexchange.com/q/12597/10976
    Oct 14, 2018 at 6:07
