While driving in 2nd gear, clutch down, try to go into 3rd (this happens like once in 30) the joystick kinda get stuck in the middle, like mid-way into the downwards 'state' as I would if I wanted to go to reverse.
I tried using as little force as possible and all-together avoid the downwards pressure but sometimes even like that it get 'stuck' in some neutral-state.
At this point if I hit the gas engine roars and RMPS go up like mad so I have to quickly swap to 2nd and try again.
It's a 2005 golf (1.6 Petrol - 170 000 kms) thats very well cared for and other then this has no issues whatsoever.
Also I'm pretty a newbie when it comes to cars but I drove two before and never had this kind of issue.
  • Welcome to Motor Vehicle Maintenance & Repair! It sounds like maybe your linkage bushings are getting worn out. – Pᴀᴜʟsᴛᴇʀ2 Oct 9 '18 at 12:21
