I have a Madza Scrum/ Suzuki curry small truck which is boiling whenever i travell just 5 kilometers, please help what might be the problem
    Have you checked the fluid level? Is there anything obstructing the flow of air through the radiator? – Solar Mike Oct 9 '18 at 10:06
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Oct 9 '18 at 13:15
I've had this problem with both a car and a motorcycle in the past. In both cases the problem was a seized thermostat.
Here is some more info on testing your thermostat: How can I test my thermostat?
If the thermostat is the problem, I'd recommend replacing it, but gutting it is also an option,
Hope this helps.
You can remove and test the thermostat to ensure it's opening at the right temp. A bad radiator/cap/blockage could also be causing a problem. That could include air in the system if it needs to be bled out in a special manor.
At worst, it could be a head/gasket problem which you can get a test for from most local autopart stores.
