My bike bike Suzuki Fiero (2001 Model) missing and jumping, reducing power when riding in rain. As per the instruction from Mechanic i changed the following ...
Changed Spark Plug and adapter Cleaned Carburetor Checked ignition switch changed the regulate
Still i am facing the problem, please Suggest a solution.
I would replace the sparkplug cable - age makes them susceptible to moisture ingress causing loss of spark. You may see stray sparks when it is dark...
  • If you're bike has a conventional distributor, the distributor cap is also subject to age- and heat-related cracking. The cracks may be too small to see, and can definitely yield bad running in damp conditions. Oct 8, 2018 at 17:47
