98 civic ex has always had “green” coolant. Now not sure if that’s original used stuff or what.
However I noticed you can’t really find regular old green coolant that uses silicates and had to be replaced every 2 years.
I found a bottle of Prestone that says it’s compatible with ANY vehicle old or new. I’m curious what this coolant has in it that makes it so compatible and the difference from the regular old green coolant and other coolants.
Is it using phosphates as corrosion inhibitors? If so and a car was designed to use the old green coolant with silicates, does mixing the two only make it a 2 year long coolant since there will be silicates in there?
