I found the below object lying under the driving handle of a 2015 Subaru Impreza. What is this thing? I'm pretty sure it fell off from behind the driving handle. Thanks.
-----edit-----
As per advice I was able to slot it back in.
So I guess I will change the question, why is there a screw sticking out? Thanks.
9
  • Welcome to Motor Vehicle Maintenance & Repair! It looks like a cap which goes on to studs or bolt ends. Oct 3, 2018 at 22:15
  • Any identifying numbers on the underside? Doesn't ring any bells immediately.
    – PeteCon
    Oct 3, 2018 at 22:21
  • @PeteCon It has a big "K" printed. Another 45 degrees rotation from there to the right, there is a mirror image of "2".
    – ztyh
    Oct 4, 2018 at 0:03
  • To hold trim or carpet?
    Oct 4, 2018 at 3:25
  • What do you mean by "driving handle"?
    – GdD
    Oct 4, 2018 at 7:22
Seeing it in place answers the question. It's a Stopper.
https://parts.subaru.com/p/Subaru__/STOPPER-PEDAL-B/49247380/36036AA031.html
All it does it stop the accelerator pedal from going too far to the floor.
