votes
Hit a curb, I’m not optimistic, but take a look y’allenter image description here
  • If you could the manufacture would already have remove it to spare thousands of dollars in rubber material
    – PDuarte
    Sep 24, 2018 at 21:01
votes
NO , do NOT continue to use that tire, the plies are exposed and will damage very rapidly either at that point, or due to moisture ingress, further away.
Put the spare on and get that one replaced, as the time of failure cannot be predicted, ie it may look ok, until you are taking a high speed corner then, suddenly you won’t be.
For your safety, and your passengers safety change it now, and other road users of course.
