On my 2007 Mazda6 3.0L: I cracked the brittle plastic tube that taps into the main intake plenum, circled in red here below. What is it called, and/or what is the replacement part number?
That should be part of the PCV system, as it attaches to the intake tract and down to the valve cover. I've looked for the line on the interwebz without luck, so don't have a part number for you.– Pᴀᴜʟsᴛᴇʀ2 ♦Sep 22, 2018 at 22:12
1 Answer
That's a breather hose from the valve cover to the intake, 8561-01198867 might be the right part number for you.
