I have a VW crafter van 57 plate have had a lot of work done to it as it kept going into limp mode.by Bosch agents in Bristol ! My problem is when going down hill on over run @ the bottom of hill when depressing the throttle pedal I get a cloud of blue smoke from the exhaust, it is then clean the van goes ok. All so at times when @ traffic lights the engine rev's go up & a lot of smoke comes out of the exhaust, I switch off the engine & restart & every thing is fine. Any Ideas
    How many miles? Turbo oil seals? Valve stem oil seals?
    Sep 22, 2018 at 14:04
  • Welcome to Motor Vehicle Maintenance & Repair! Agree with Mike here and wondering the same things. Seems like you've got oil being drawn into intake tract at times of high vacuum. Sep 22, 2018 at 14:12
    For those not in the UK, a 57 place means it's a 2007.
    – GdD
    Sep 22, 2018 at 14:20
-1
I had this issue on 07 plate 2.5l crafter after deaccelerating say like going down a hill, first touch of throttle after this would result in big puff of smoke but absolutely fine at all other times, it was the lambda sensor. changed this and it is now totally cured.only got this idea to change it from reading forums like this.
