I have a 04 jeep grand cherokee special edition and the factory harness was cut out so I figured whatever I'll just hard wire it. Found all the speaker wire colors matches them up but the battery wires which I assumed were the two red and white ones don't have power running to them but the two black ones do. I thought those were the ground. The illumination has constant power. So, I hooked them up with the black to battery since it's constant and the red and white to ground but it keeps popping the fuse in the back of the radio. Am I missing something ? I can't find and diagrams or forums with this issue. Please help !!!
    BTW, Khayla ... Welcome to Motor Vehicle Maintenance & Repair! Welcome to Motor Vehicle Maintenance & Repair! Commented Sep 20, 2018 at 20:38
  • No it's an after market radio but when I first hooked it up obv red and white to battery etc there was no power to the head unit. So, I took a test light to the wires and no power to the red and white but power to both black also 12v on the meter and when i tested for ground wires the red and white lit up , I figured constant power to battery etc but now it's popping the fuse. I'm not an idiot but this don't make sense.
    – Khayla
    Commented Sep 20, 2018 at 20:47
Here are the diagrams for the base sound system, colors are the same for Premium Sound.
  • Thank you. +1 for answering and making it complete with diagrams :o) Commented Sep 20, 2018 at 20:55
  • There should be 2 power wires on the new head unit, one is batt and should be yellow, the other is accy and should be red, connect them separately, there should be only one black wire on the new head unit, connect it to either one of the black harness wires.
    – Moab
    Commented Sep 20, 2018 at 21:55
  • I'm asking about from the jeep
    – Khayla
    Commented Sep 20, 2018 at 22:29
  • 2 Red/white to yellow, white/red to red and 2 black to black or should i ground one black to the back of radio and other to the ground of harness ?
    – Khayla
    Commented Sep 20, 2018 at 22:31
  • just the black wire out of the radio to one of the black wires in the Jeep harness.
    – Moab
    Commented Sep 21, 2018 at 12:54
