This is a Subaru Forester 2003.
The car start losing power after a few minutes on the road. And suddenly lost all power and is almost impossible to drive.
Already changed:
  • fuel pump
  • spark plugs
  • ignition coil
  • O2 sensor
  • fuel filter
The car had no check engine codes. The catalytic converter is new, less than 3 years old.
    Welcome to Motor Vehicle Maintenance & Repair! Sep 19, 2018 at 2:06
    When you say there's no check engine codes does that mean that there's no check engine light on the dash, or that you've read the OBD codes using a reader?
    – GdD
    Sep 19, 2018 at 7:24
    Completely random guess, but did you check the earth straps. There should be a braided cable on each head, connecting the engine to the body. If one or both are missing, weird things can happen. They're often overlooked, and broken/torn off if the engine is removed without them being disconnected.
    – PeteCon
    Sep 19, 2018 at 14:05
  • Has no Check engine codes at this moment, a while ago had the p0447 code which was a broken cable and the p0420 that says Catalyst System Efficiency Below Threshold) bank1. And the O2 code but I already replace the sensor already. Right now doesn't show any codes Sep 19, 2018 at 14:20
    Do you have any way to test fuel pressure ?
    – Pierre P.
    Sep 19, 2018 at 15:26
Catalytic converters can go bad pretty quickly when engines are out of tune. p0420 is possibly that.
The definitive test is a pressure gauge where the O2 sensor is.
If the compression on the motor is good (compression test) you need to look elsewhere. If compression is low on all cylinders - timing belt jumped a tooth.
Vacuum gauge will also give you an idea. If, at idle, the vacuum slowly goes to zero, you are no longer 'pumping air' and also points to a clog.
I had one motor loose power when 3 rocker arms jumped off (Chrsler 4.7, overhead cam) Compression check was weird, leak down test was also weird. I suspect owner didn't change the oil often enough and hydraulic adjusters (like lifters) were all coked up/clogged. Reved it too much when cold.... No noise from engine, no check engine line, just way down on power.
