I've got an old Opel (Vauxhall) Vectra 96 that hasn't been used for a long time. This spring I tested it and the motor started fine, though I had to use jump cables because the battery is completely dead.
I tried again now but when I turn the key the starter doesn't manage to turn and the lights on the dashboard turn off. It's the same even when using jump cables and I also tried disconnecting from the battery's plus pole, just in case the battery was the problem.
Is there a common cause for a short circuit that might cause this or what could it be?
    Welcome to Motor Vehicle Maintenance & Repair! I'd suggest you recheck your jumper connection. Keep the battery in the loop, as it helps protect other electrical parts as a surge protector of sorts. Charging the battery prior might help as well. Sep 11, 2018 at 10:46
I would replace the dead battery with a working one altogether: that excludes jumper cables and a dead battery sinking current from the good one out of the equation.
If the car still doesn't start, it's a connection somewhere. Start from the battery and check the voltage past different cables to see where you lose it.
