2003 Renault Megane 1.4. Will not start. Code reader gave message that cylinder 4 misfiring, but have replaced it and also pencil coil. Zeroed the code reader. Checked fuse box - no corrosion/grease. Any thoughts thanks.
You replaced what? I have some difficulty believing you replaced "it", i.e. cylinder 4. If you replaced the spark plug, say so. – juhist Sep 7 '18 at 12:25
yes, replaced the spark plug and pencil coil. – john Sep 7 '18 at 12:26
Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Sep 7 '18 at 12:30
Does it turn over on the starter? Has it got fuel? Is the fuel getting to the cylinders? – Solar Mike Sep 7 '18 at 12:31
Yes it turns over. When I remove the plug it is wet so I assume it has fuel. – john Sep 7 '18 at 12:32
