When buying 2 salvaged vehicles, one totaled in the front and the other in the rear, to make 1 whole car where do I go to check the capability of 2 different years cars? What vehicles have the most match across the year models? I understand that some years have no other match, but I am looking for the most abundant match.
Bonus question and example My car is a 2001 Toyota Camry how far out side of this year model to use the parts that all match?
closed as too broad by MooseLucifer, 3Dave, Bob Cross Sep 7 '18 at 0:59
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • This question is extremely broad. What kind of a time frame are you talking about? As written, you're suggesting information on all vehicles ever made. That's literally tens of thousands of different makes/models. I'm not sure this question is a very good question for the site, even if you trim down what you're talking about. – Pᴀᴜʟsᴛᴇʀ2 Sep 6 '18 at 22:04
  • @Pᴀᴜʟsᴛᴇʀ2 Make be the question should read... what is the most vehicle including cross capability? – user22295 Sep 6 '18 at 22:15
    I don't think there's any way for this question to be answerable. There are just too many makes and models, and too many variations in how vehicles are assembled. How would you even verify that the answer is correct? – barbecue Sep 6 '18 at 22:31
  • The most vehicle including cross capability is a bicycle. Most parts are interchangeable. – 3Dave Sep 6 '18 at 23:48
    Doing this in the UK is almost certainly illegal, if you intend to drive the repaired vehicle on public roads. For example it can not be registered, and would fail the annual MOT safety test simply because the VIN numbers on the vehicle didn't match the registration, unless it was put through an "approval test" and given a special (so called Q) registration number. Of course it is possible to go through this process (e.g. to legally operate a "stretch limo") but the majority of such "cut and shut" vehicles are not legal, and probably not safe to drive either. – alephzero Sep 7 '18 at 0:06
The easiest (and only) way to answer is to look at your specific vehicle. This is an XV20 model, made from 1996 to 2001. It was also known as the Daihatsu Altis, Toyota Vienta and Toyota Camry Gracia - but there's no shortage of Camrys in the junk yards if you're looking for parts. Be aware that a car that old isn't worth much - where is the benefit in buying two broken ones to make one that works? For the same price, you'll probably find a decent one.
  • Cosmetically no change over on engine and such. – user22295 Sep 6 '18 at 23:21
    @Muze Not to bait the trolls, but many of your "sentences" lack a verb. – 3Dave Sep 7 '18 at 0:57
