While I have a good knowledge on general service procedures for a vehicles engine, suspension, exhaust and other usual systems, I'm unsure of how to keep a vehicles electrical system in top-notch.
My question is, does the electrical system require routine maintenance, and if so, what tasks would it involve?
Well, not much, but things to check include:
1) battery terminals - clean, tight and some protection ie petroleum jelly works well on lead/acid batteries
2) all cables (easily visible) are not rubbing or chafing anywhere
3) all bulbs / lights function.
Used to have distributors on the list and brush height & rear bearing to oil in dynamos etc but times change.
Provided you have the required tools, I would add:
4) Load testing the battery
5) Testing alternator output
and no tools required...
6) Making sure the top and sides of the battery itself are clean to prevent stray voltage loss
