I have a 2012 Ford Fusion SEL and have decided to try to replace brakes and rotors myself. I have successfully got the caliper and piston removed. Successfully reset the piston. Put the new rotors on and started putting things back together.
When I try to out the caliper assembly back, 1 bolt wont go in all the way and will stop in 1 spot. This prevents anything else from being seated properly. Any ideas on how to get the bolt past this spot?
The short one represents the bolt going in properly but the one sticking out is stuck in that position
