Today I noticed something annoying on my 01 UL LS430, The RPM rate drops to around 500 when I set the transmission to "D" along with a slight vibration and strangely. If i change that to P, N. or even Reverse. It jumps back to 700 normally. Above numbers are while no AC/Headlights on. If i turn on the AC, the headlights or the seat heater. those 500 jumps to 700.
What I tried so far:
- Cleaned Air filter, MAF, Throttle body and those throttle upper tiny holes (dunno their name).
- Spark Plugs are brand new, didn't even reach 20.000 km yet.
- Hooked up an OBD2 comprehensive tester and it showed absolutely nothing wrong.
- Un-plugged the MAF sensor while the car is idling and it immediately shut off (Saw it somewhere, that this can determine if the MAF sensor is working or not).
Any suggestions?
