I have an Avensis 11. The central locking works every time, but unlocking doesn't
It only unlocks the boot and turns the alarm off. Then I have to use the key to unlock the driver door, then the 3 other doors need unlocking manually.
UNLESS the day has been lovely and warm, or I have driven for about an hour then it will work ONCE and once only.
I took it to the Toyota garage and they told me I needed a new door lock, which had zero effect. My local dealer is about an hours drive away, so uses up a whole day going to them as I have to sit and wait for them to finish.
What could it be?
12
  • Was this resolved @WendyG? I have the same problem.
    – Levi
    Apr 18, 2019 at 0:14
  • @Levi no my research says I need a new ECU (electronics control unit) which is getting expensive.
    – WendyG
    Apr 18, 2019 at 9:05
  • @levi where in the world are you, as it may be worth getting this seen together, as I know I am not alone. I am in the UK
    – WendyG
    Apr 18, 2019 at 9:06
  • UK too - London @WendyG
    – Levi
    Apr 18, 2019 at 13:04
  • @Levi, up north, I wonder if this can be co-ordinated
    – WendyG
    Apr 18, 2019 at 13:56
