I am looking at buying a second hand 2-stroke engine. I have seen a lot online about checking compression before buying used engines. I don't have a compression tester, but will buy one if necessary.
My question is, if the engine starts and runs fine, does that automatically mean the compression is okay, or should I still check the compression?
Thanks in advance!
