I have 2002 ford focus and I installed a new stereo system it was working fine.... then I had to pull the stereo out again b/c I forgot to install Mic. and cig lighter.... after I hooked those things up I went to push the unit back in...... and the stereo went dead......
At first, I thought it was a fuse or relay
so I check fuse box under the steering wheel..... Nothing Blown
Then
check the fuse box under the hood...... Nothing Blown
So that was all good
SO FUSES AND RELAYS ARE GOOD.........
Is there a third fuse box under dash????
The New stereo unit has two wire harness inputs
One for speakers and audio
Second one is for POWER (((( PROBLEM))))))
(Consist of )
*GROUND
*12V BATTERY WIRE
*12V IGNITION WIRE
((((I tested this one with a volt meter and it was dead even when key turned)))))
I crossed the *12V IGNITION WIRE & *12V BATTERY WIRE
The Stereo Unit powered on....
Something is causing my 12V ignition wire for the stereo not to function
Any ideas
7
  • How did you check the fuses? Visual only? Also, it's certainly possible there's another fuse - perhaps an inline one. Was the previous radio an aftermarket? IME, those are more likely to have an inline fuse than a factory radio. Can you physically inspect the wiring back from the radio to the power source?
    – mike65535
    Aug 13, 2018 at 12:19
  • I checked the fuses visually with a flashlight. The wire goes from the dash into the firewall no clue after that. I wish I had 2002 Ford Focus Electrical Wiring Diagram. The previous radio is Factory original but I notice today that radio no longer turns itself off or on. I cant inspect the wire cause no clue were it goes and its wrapped in protective foam
    – MIKE
    Aug 13, 2018 at 20:56
  • Check with a ohm meter / continuity checker
    – mike65535
    Aug 13, 2018 at 23:32
  • Does the car run? If so, then I'd doubt that the fuses for ignition are blown... Unless that's not exactly what it is. Aug 14, 2018 at 1:35
  • car runs and drives
    – MIKE
    Aug 14, 2018 at 2:52
The ignition 12v wire has a fuse blown most likely, recheck your fuses. Fuses F31 (ign 30A) and F41 (Battery 7.5A) in The Central junction fuse box, behind dash panel LH side, may be concealed behind the knee panel.
  • Are the fuses you stated match my 2002 ford focus
    – MIKE
    Aug 13, 2018 at 21:02
  • According to my repair information, yes.
    – Moab
    Aug 14, 2018 at 12:46
  • any others to check that would affect the 12V IGNITION WIRE
    – MIKE
    Aug 15, 2018 at 5:42
  • Thank you so much.... it ended up being the cluster accessory (fuse 41) tested with amp tester it was shot
    – MIKE
    Aug 15, 2018 at 23:01
    @MIKE Please upvote and mark my answer as solution, thanks.
    – Moab
    Aug 19, 2018 at 21:48
