I need to decide upon a pair of bolts that will be used on my motorcycle to mount a pair of frame sliders. The already present frame sliders are installed with (supposingly???) 10.9 grade M10x1.25x70mm (silver colored) bolts with hex socket heads. These two have slightly bent heads due to previous owner minor motorcycle drops and are acting as engine mounts as well. These two are not the original Yamaha factory bolts and probably came with the aftermarket protective mushrooms. This specific bolt size is quite hard to find in my country (Greece) furthermore for stainless material. Would it be safe to replace these with A2 grade stainless??? If not what is the minimum standard that i should try to match??? Any suggestions on how to shop these in Greece-Europe will be much appreciated...
A similar question (although different exact bolts) has been asked already: mechanics.stackexchange.com/questions/42894/… – juhist Aug 1 '18 at 14:17
@juhist I believe brake calipers bolts are quite different than frame sliders mounting bolts in terms of forces and desirable bending-snapping behavior. I believe brakes need very rigid "unelastic" screws to maintain a firm operation under great forces but if you happen to drop your bike on a very hard bolt screwed on your motor block you might find yourself in the same position as the bolt. – kokobill Aug 1 '18 at 15:28
I wouldn't trust the bolts you currently have to be right for the job, and I would definitely not replace them with some bolts you found at the local hardware store, and you don't have to. You should start by finding out the Yamaha part number, googling "Yamaha [year] [model] engine mount bolts" should bring up all sorts of useful information.
Once you have the part number go online to virtually any parts store on the planet and order them. There's loads of them in the EU, you don't have to order them from a Greek site. eBay is actually a good source of spare parts as long as you buy from sellers with a good reputation, some parts shops have their own eBay stores.
Lastly, you could just contact a Yamaha dealer and tell them what you need. You'll pay a bit more but you'll get exactly the right part.
EDIT: The OP explained that the original part number is 91314-10040, but wants a longer one. Yamaha bolt part numbers have the size as the second part, 10040 means M10, 40mm, so 10070 would give you a 70mm bolt. Unfortunately there's no corresponding part number, so I would go with a M10 70mm 1.25 thread (if you're sure that's correct), marine grade steel with the head type you want (hex head probably). A google search again will help you here, and you can order from anywhere.
Sorry if i didn't make my self clear but the bolts placed at the moment are NOT the original ones. The original Yamaha bolts (part No. 91314-10040) are way shorter than the ones i need. The ones i need have to be 70mm lengthwise because i want to KEEP the protective mushrooms installed. – kokobill Aug 1 '18 at 14:31
Whatever replacement bolt you choose has to meet or exceed the standards of the original bolt - that is assuming those original ones you have are original and not some monkey-mechanic replacement from a bucket...
As for shopping I can suggest where I go but it won't help...
