I'm driving a 2018 Hyundai I10. It's got three seats in the back, each with a seatbelt. But I can't find the middle seatbelt's buckle (not the tongue — I've found that — but the socket for it). Obviously I've looked between the seats and their backs, including lifting the middle seat forward, and in the hollow that holds the other seat's buckle, and have tried reaching into the seat backs. Does anyone know where it might be hiding?
Some pics (that link to larger versions):
(picture of the center seat in the rear)
(picture of the center seat in the rear, when the seat is pulled up and forward)
9
  • Daft question maybe, but the socket - is it designed to take two tongues? ie it has two slots...
    Jul 30, 2018 at 20:04
    If the three backseats are essentially one long bench seat, the "socket" for the middle seat's belt will often share an opening with the socket for one of the outer seats.
    – mike65535
    Jul 30, 2018 at 20:07
    Literally take it back to the dealership (any Hyundai dealership) and have them find it for you. If it's actually missing, they'll have to put one in for you. I believe warranties are world wide, aren't they? If they find it, you're golden. More than likely it's hiding under the seat and you just haven't found it yet. Jul 30, 2018 at 20:32
  • @sol I had checked that also. No dice. But thanks for the idea.
    – msh210
    Jul 30, 2018 at 21:23
    @mik thanks. That's what I meant by "hollow" in the question. (If I understand you right.)
    – msh210
    Jul 30, 2018 at 21:25
From what I can tell in the owner's manual (on page 52 of 360), the rear seat's center position uses a lap belt from the right (when viewed head on) to the left. This places the missing latch immediately beside the left seat's latch:
rear center seat belt position on Hyundai i10
Note carefully the caveat in that image, however: if equipped. You said you found the tongue, so you must have found that lap belt. Therefore, you'd expect to find its latch mate on the left side.
However, from the pictures in the OP, I'm not seeing the lap belt, so I'm dubious this i10 is equipped per the manual's caveat.
  • I had seen that in the manual and assumed that the parenthetical "if equipped" meant that in some cars the middle buckle is equipped (so to speak) with the "CENTER" mark and in others it's not. But maybe you're right.
    – msh210
    Aug 3, 2018 at 3:42
Is it possible that your car came with only TWO rear passengers setup (and belts-buckles as well) as a cheaper version? Cars with 3 rear passengers seats often have a horizontal belt for the center passenger which i cannot see in your pictures, so it might be completely missing out the center passenger setup.
  • The center seat's belt is in the picture.
    – msh210
    Aug 3, 2018 at 13:27
  • @msh210 Is it? I'm expecting to see a lap belt per the OM, and I am not. Can you circle/highlight the center belt in your photos?
    – bishop
    Aug 3, 2018 at 13:53
  • 4
    The centre belt is clearly visible in the photograph. It's the only seatbelt that can be seen. In certain jurisdictions (UK for example), a "lap belt" is no longer legal and all rear belts must be three point minimum. I suspect they've simply forgotten to install it at the factory although I would suggest looking under the other seat cushion. Aug 3, 2018 at 14:45
