I've got a 2014 Honda Accord V6. The positive batter terminal has been corroded for several months now. I first noticed it in January but never got around to removing the corrosion until today. I removed the battery and cleaned everything off with baking soda, but now the car won't start. It seems like the battery terminal has corroded too thin to make any contact.
  • Also when trying to tighten the nut, it torques the entire terminal upwards. So I can't tighten that terminal at all.
    – Davy Li
    Commented Jul 21, 2018 at 17:42
  • If it's loose, as a temporary fix you can cut up a soda can to shim the terminal until you can replace it.
    – Ben
    Commented Jul 21, 2018 at 20:56
  • Lightly scraping both the inside of the clamp and the terminal itself will probably get you good connectivity. You want to have fresh metal showing. If you are still loose, do as @Ben says for the meantime. Commented Jul 21, 2018 at 21:05
I would remove that terminal and fit a new one - new terminals are available at most auto spares shops.
Do make sure that you get the correct one (positive terminals are larger than negative ones) - the symbol just to the bottom left of the battery post does seem to show negative but as you say it is positive - just make sure...
12
  • Red is pretty indicative of a positive terminal. Also, doesn't the Honda battery terminals incorporate some kind of fusible link in them? While I agree with you this should be replaced, it may be a little tougher than going down to the parts store to find one. Commented Jul 21, 2018 at 20:41
  • @Pᴀᴜʟsᴛᴇʀ2 maybe maybe, but what is the symbol molded into the battery surface to the bottom left of the battery post...
    Commented Jul 21, 2018 at 20:43
  • I don't think it is a symbol. It looks like the cell cap. @paulster2 Honda puts the fusible link in the underhood fuse box
    – Ben
    Commented Jul 21, 2018 at 20:47
  • Well, only an image of the complete top of the battery will confirm exactly what is what...
    Commented Jul 21, 2018 at 20:48
  • Besides, the positive corrodes green, while the negative corrodes white. Thanks for the heads upon the fusible link, @Ben. Commented Jul 21, 2018 at 21:03
