I would like to know how to stArt my 76 chevy pickup without a key. The steering column is not locked but the ignition switch will not turn. It is a four speed standard transmission. I dont have title or keys for the truck yet, it was basically given to me as a restoration project
Drop the steering column from its mount, then you can access the ignition switch, un-mount the ign switch, now you can use a small screwdriver to work the switch to start the truck. That or replace the lock cylinder with a new one.– MoabJul 20, 2018 at 19:18
