When I changed the spark plugs on my 08' 4Runner, I noticed it had alternating Denso and NGK sparks plugs in the engine. The manual has them both listed: Denso (K20HR-U11) and NGK (LFR6C-11). What is the purpose of installing two different brands? Does this practice add any mechanical benefit?
1If it's an 08 then it's not the manufacturer, but whoever last changed the plugs. – GdD Jul 16 '18 at 12:15
As far as I'm aware, there is no benefit to having a mixture of plugs, and in fact it may have a negative impact as one sort may burn slightly hotter than the other - though I very much doubt it would be enough to be noticable.
The reason for listing multiple brands in the manual is simply to allow you the option - if you can't get hold of one brand, there's an alternative. It may also be that it reduces cost in the factory - they will buy then in huge batches, as as the prices fluctuate slightly it would enable them to buy whichever is cheapest on any given day/week.
I suspect that the reason you've got a mixture in your car is simply down to a mistake - either in the factoy (not unheard of!) or by whoever last changed them...
I'd fit a full set of matching plugs, of whichever of the two brands is easier/cheaper to get in your local parts store...
1And also JIT ie who has stock to be able to deliver at that time point. Most likely it was a « cheap » mechanic only doing the easiest two... – Solar Mike Jul 16 '18 at 11:24
