Every time I used to drain and add oil it would quickly turn black. That was most probably because i've been driving with a faulty o2 sensor and apparently the air fuel ration due to this is one reason oil turns black.
Oil is low at the moment and need to top up, is it ok to mix with the existing black oil(which has become black for above reason) or must it be drained and new oil put in? If so what is so bad about oil which has turned black from the improper air fuel ratio?
Thanks
