First timer here and I ran over something on the highway and this is the damage I got..... should I get the rim replace or is still OK to drive on
Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Jul 7 '18 at 19:37
You need to replace the tire and the rim or, replace the tire and get the rim professionally repaired - which will need welding, then machining, checking for roundness and then the new tire fitting and balancing.
Do NOT drive on this as it is - fit the spare...
