I can not get the wipers to work. Ive replaced the motor but there is no power to the fuse and i put a new one in today
    Welcome to Motor Vehicle Maintenance & Repair! Jul 4, 2018 at 3:16
There are fusible links that feed the fuse panel, they are connected at the starter battery terminal, if there is not 12v at the washer fuse then one of these fusible links is broken, blown or not connected on the last starter change.
  • Is there a relay somewhere? Jul 4, 2018 at 14:23
  • Not any outside of the washer motor assembly, just a fuse, and the wiper switch assembly. See my added image above.
    – Moab
    Jul 4, 2018 at 14:34
  • Ok i just replaced the motor but there is still no voltage at the fuse what else would cause that Jul 4, 2018 at 14:52
  • Then it is most likely a fusible link as I explained in my answer.
    – Moab
    Jul 4, 2018 at 15:06
    I checked all the fusible links and one was bad but after i fixed it. The wipers still do not work Jul 13, 2018 at 22:01
You need to correct the lack of supply to the fuse.
Are there other items not working?
Temporarily bridging a supply will enable testing of the new motor.
This could be a damaged fuse box or loose connector or broken wire.
    The radio is not working too and all the wires still have the factory wrap around them. Is there a relay somewhere because thats what my mobile mechanic said last night to check but i dont know where it is Jul 4, 2018 at 12:43
