I have a 2000 Dodge Durango with an ABS system. Earlier this week, I realized that one of my wheel cylinders had a leak, and I ran out of brake fluid (good thing it was not while driving). Anyways, I have replaced the wheel cylinder, and I have bled it.
That being said, I believe I heard somewhere that when an ABS system runs dry, it needs to be electronically bled to get all of the air out of the system. Am I remembering this correctly?
Thank you for your time.
  • Welcome to Motor Vehicle Maintenance & Repair! Jun 28, 2018 at 15:52
    Yes, you need to activate the ABS to bleed the pump, either electronically or.. dangerously. Jun 28, 2018 at 16:19
yes there is additional bleeding required. From a shop manual:
