when I plugged in my OBD scanner, I got not connected to the vehicle and the dashboard going crazy, and when I unplug the ODB scanner everything going back to normal... the vehicle I am talking about is Dodge Journey 2011, I have problem with the PCM, I bought a used PCM and in order to crank the car I had to input the VIN to new (USED PCM), accordingly I did, and a successful message appeared then the scanner disconnected with the Car and then I tried to connect\ communicate with the car but there was no luck... and then a new thing happened as the tachometer going crazy when the OBD scanner is connected and it back to normal when I unplugged the scanner.... any can help please
  • 3
    Is the scanner the correct one for the vehicle? Are the pins damaged? Are any wires damaged? Was the plug seated correctly?
    Jun 27, 2018 at 9:13
  • Welcome to Motor Vehicle Maintenance & Repair! Jun 27, 2018 at 15:29
