I am from India, here we have Ford Ecosport. Tt has different models, out of which one model with less cc produces more power than a higher cc model (999cc and 125ps) & (1497cc 123ps). How is this possible? What are the advantages and disadvantages of less cc more power vehicles? enter image description here
  • Is the larger engine an older model still on sale? Newer engines are tuned to a higher standard and can produce the same or more power with less displacement...
    Jun 25, 2018 at 6:34
  • Are they the correct specs you have shown there? One has a heading for 1.0 GTDi which sounds like a diesel.
    – HandyHowie
    Jun 25, 2018 at 7:46
  • The lower compression ratio and the large RPM range with max. torque indicate that the 999cc engine is turbo- and/or supercharged while the other one is not.
    – JimmyB
    Jun 25, 2018 at 11:06
  • @HandyHowie 6000 rpm and a 10:1 compression ratio don't sound like Diesel.
    – JimmyB
    Jun 25, 2018 at 11:10
  • It is also direct injected.
    – Moab
    Jun 25, 2018 at 12:56
I am guessing that the smaller engine has a turbocharger and the larger engine doesn’t. This would fit with the smaller engine having a lower compression ratio.
The turbo compresses the air entering the engine allowing more fuel to be added. The small engine will therefore in effect have a larger capacity and will therefore be more powerful.
The smaller engine will likely have a small amount of turbo lag, whereas the larger engine will likely be more responsive at lower revs.
Insurance may be more expensive on the more “sporty” turbo engine.
After doing a bit of research, it looks like the generation 1 of the 1.0 had a supercharger and the generation 2 has a turbo charger, while the 1.5 is a normally aspirated.
  • I would agree. The "GDTI" moniker would also lend to this theory. The "T" is usually an indication of turbocharging. Jun 25, 2018 at 8:25
  • You'll often find that insurance prices are linked to the displacement more than the horse power, so a turbo can give better value insurance than the larger engine. Jun 25, 2018 at 15:09
how is it possible?
Turbo/ Supercharging, higher tuning, there are a lot of possibilities to make more power out of an engine.
what are the advantages & disadvantages of less cc more power vehicles
Advantages of the "smaller" engine:
  • Possibly less weight.
  • Better fuel efficentcy
  • Less material consumed in making it (but could be offset by added turbocharger)
  • More power in high revs.
Disadvantages:
  • More and complicated moving parts.
  • Potentially less sturdy.
  • Less torque in low revs.
