I have among many cars, a 2005 Chevy cobalt LS. it's a nightmare! Spend more time under it than driving it. So recently I replaced the front passenger ball joint, and the driver's side rear coil spring. The area I live in is pothole h311. Suspension and steering problems are constant. Now I have a loud clicking/thumping sound coming from the rear end. I'm not positive but I think it's the drivers side. It usually makes this noise when first taking off after several(or more) hours of not moving. After about 5 minutes it seems to stop, however it will start again randomly or sometimes when turning. It's very unpredictable, it's getting progressively louder and recently has started shaking the car when making said noise. Sometimes it's the clicking sound similar to a bad CV joint, others its more of a thumping sound like a flat tire. The alignment is dead on center, the steering wheel doesn't pull ever, no shaking in the or vibration either. I want to say it's just a broken belt in the tire, however the fact it isn't a constant continuous problem makes me think otherwise. Any thoughts? Possibly a bad strut??
  • Welcome to Motor Vehicle Maintenance & Repair! I'd check the condition of the strut and where it attaches to the body. Sounds like the mounting rubber there or at the spring cups could be causing you issues. Commented Jun 23, 2018 at 12:39
  • This sounds like a "Friday car" ie one made on a Friday when the workers wanted to get home quick... So if you have all the other cars, sell it and get something else - it is obvious you don't like it...
    Commented Jun 23, 2018 at 13:11
  • I'd love to. Unfortunately the old lady loves it Commented Jun 24, 2018 at 3:21
If your tire had a bad belt or a problem that could shake the car it would be 1) visible and 2) constant. As this is a front wheel drive car there's no rear axle, diff or CV joints, so the problem is almost certainly in the rear suspension, which is a torsion beam with a spring and shock. You've recently disassembled the rear drivers side to replace the spring and that's where you think the sound/vibration is coming from, I'm going to hazard a guess that the problem lies there.
The very first thing I'd check is that the wheel has been bolted on properly, it's one of those id10t errors that anyone can do. Check the other side as well, it will take a few extra seconds.
If the wheel is on right then you need to check the suspension. It's possible that when you replaced the spring you didn't re-assemble the suspension correctly. It's also possible that some of the bushings have degraded and couldn't handle being re-used, or that another component has failed since. I'd jack it up and waggle tire around, see if there's play. Get a pry-bar or breaker bar in there and find out what's broken or come loose.
  • I finally discovered that the issue was as follows. The strut on the passenger rear was not properly bolted to the frame. This caused the tire to shift in an upward slightly off center rotation pattern. The lug bolts bent just slightly because of this causing a slipped band. As well as some minor bending of the inner rim. A combination of these things is what caused the issues. However the root of the problem in fact as you said led directly back to the recently replaced springs Commented Jun 24, 2018 at 3:19
  • Ouch! This is a nightmare car @iHATEmyCOBALT! I feel your pain.
    – GdD
    Commented Jun 24, 2018 at 8:10
