My 2008 Ford Escape started doing this on the way home today - scared me to death! I was coming downhill on a left-turning road and I felt like I had blown a tire and was riding on the rim - some loss of control, a grinding sound. As I went (slowly) home, I figured out that it only happens when braking and turning left. Google was unhelpful - just got a lot of results about grinding noises when turning in general.
1I would have the wheel bearings checked on the front. – Moab Jun 12 '18 at 21:37
Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2♦ Jun 12 '18 at 22:10
Wouldn't bearing make noise more often? – DeltaG Jun 13 '18 at 0:46
Check the state of the front brake calipers and pads – MadMarky Jun 13 '18 at 7:53
This sounds like a CV axle problem, a bearing noise would be constant and vary with speed. – GdD Jun 13 '18 at 7:57
Show 1 more comments
OK, here's the scoop:
It was the left front tone ring, which was causing the ABS to misfire.
Wow, that's crazy! There'd have to be something causing the reluctor ring to get out of alignment (at least I'm assuming that's what happened). Hopefully you figured out what was causing this to happen. – Pᴀᴜʟsᴛᴇʀ2♦ Jun 14 '18 at 17:16
Can't speak to that - just found out about the existence of a tone ring :) Got it back from the shop today, and all seems well so far. Side note: guy said that the Escape is fairly unique in that the tone ring can be replaced without the whole assembly being changed out, so it wasn't horrendous – DeltaG Jun 14 '18 at 21:52
