When I put the key in all the lights turned on and everything except it doesn't want to start and doesn't make no noise or nothing just nothing
  • Welcome to Motor Vehicle Maintenance & Repair! What have you tried to do? Have you measured the voltage at the battery? What lights are on on the dash? Is there one with a green key (might be blinking)? Jun 10, 2018 at 21:21
I have had the same problem with my Prelude from 83.
Its probably your car battery.
Get a multi-meter and measure the car battery.
keep the pins on the battery and then ask someone else to start the car.
If you see that the battery loses a significant amount of voltage/amperage it means the battery is dead.
    Welcome to Motor Vehicle Maintenance & Repair! Jan 16, 2019 at 14:36
