I have a 2002 grand caravan it goes about 50 feet then just act like it's in neutral I can turn it off put it in park start back up and it goes about another 50 feeding does it again anybody know why this is happening
Welcome to Motor Vehicle Maintenance & Repair! Have you checked the transmission fluid to ensure it's where it should be?– Pᴀᴜʟsᴛᴇʀ2 ♦Jun 9, 2018 at 20:07
Any transmission codes in the computer? Is it full on fluid?– MoabJun 9, 2018 at 20:24
Have you checked the motor mounts? With a chock block in front and behind the front wheel, have someone shift from forward to reverse and back to forward. Does the motor seem to move excessively? A bad motor mount may allow the motor to move enough to shift it out of gear.– mikesJun 10, 2018 at 1:50
