I have replaced the handbrake cable on my Vauxhall Corsa and adjusted it from the inside of the car but the back brakes are still not working properly. Any ideas on how I can fix this problem?
    Did you adjust the rears or check to see if they were working?
    – Ben
    Jun 8, 2018 at 12:32
  • Welcome to Motor Vehicle Maintenance & Repair! What @Ben said :o) Jun 8, 2018 at 19:06
  • It would help if you gave a bit more details @John, did you replace the cable because it failed or because your handbrake wasn't working? What's the history here?
    – GdD
    Jun 8, 2018 at 20:54
